メインコンテンツにスキップ
IBM Thinkpad T60 Keyboard Replacement
必要な工具と部品
  1. IBM Thinkpad T60 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Keyboard Replacement: 手順 2、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement: 手順 2、 2の画像 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Keyboard Replacement, Palm Rest: 手順 3、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement, Palm Rest: 手順 3、 2の画像 2
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
  4. IBM Thinkpad T60 Keyboard Replacement: 手順 4、 1の画像 1
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Keyboard Replacement: 手順 5、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement: 手順 5、 2の画像 2
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
    • Detach the connector by pulling upwards on the white tab.
  6. IBM Thinkpad T60 Keyboard Replacement, Keyboard: 手順 6、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement, Keyboard: 手順 6、 2の画像 2
    • Turn the Thinkpad over so you can see the bottom.
    • Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
  7. IBM Thinkpad T60 Keyboard Replacement: 手順 7、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement: 手順 7、 2の画像 2
    • First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
    • Lift the keyboard until you are able to see the wire connection
  8. IBM Thinkpad T60 Keyboard Replacement: 手順 8、 2の画像 1 IBM Thinkpad T60 Keyboard Replacement: 手順 8、 2の画像 2
    • Pull upwards on the connector to disconnect the keyboard.
    • The keyboard is now disconnected.
終わりに
7 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Dylan Kratochvil
メンバー登録日: 01/30/13
591 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S7G9
4 メンバー
16のガイドは作成済み
コメント 1 件
Die Anleitung war gut.
Müller, Christine - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 16
今までの合計 4,761
