メインコンテンツにスキップ
IBM ThinkPad t43 WiFi Card Replacement
必要な工具と部品
  1. IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: 手順 1、 2の画像 1 IBM ThinkPad t43 WiFi Card Replacement, WiFi Card: 手順 1、 2の画像 2
    • Start with the laptop with the side with the logo facing down.
    • Next you will have to remove all the screws in the red circles
    • When removing the screws try to place them in order of removal on a magnetic pad. It will help when you put them back and lowers the chance of losing them
  2. IBM ThinkPad t43 WiFi Card Replacement: 手順 2、 2の画像 1 IBM ThinkPad t43 WiFi Card Replacement: 手順 2、 2の画像 2
    • Flip the laptop so that the logo is now facing up
    • locate the lock switch on the front right
    • Slide the switch to the right to unlock the laptop
    • Make sure to unlock the laptop before opening because the keyboard may still be attached
  3. IBM ThinkPad t43 WiFi Card Replacement: 手順 3、 2の画像 1 IBM ThinkPad t43 WiFi Card Replacement: 手順 3、 2の画像 2
    • Lift open the laptop
    • The keyboard should be detached from the bottom part of the laptop
    • Hold the edges of the keyboard and slowly pull up until it opens
    • Do not pull off the keyboard completely because there is a ribbon cable attached
  4. IBM ThinkPad t43 WiFi Card Replacement: 手順 4、 2の画像 1 IBM ThinkPad t43 WiFi Card Replacement: 手順 4、 2の画像 2
    • Disconnect the ribbon cable by simply lifting it up
  5. IBM ThinkPad t43 WiFi Card Replacement: 手順 5、 1の画像 1
    • The WiFi-Card is located towards the middle bottom of the laptop
  6. IBM ThinkPad t43 WiFi Card Replacement: 手順 6、 2の画像 1 IBM ThinkPad t43 WiFi Card Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Locate the two wires connected at the top of the WiFi-Card
    • Hold the card down and use the tweezers to pinch the plug and pull up.
  7. IBM ThinkPad t43 WiFi Card Replacement: 手順 7、 3の画像 1 IBM ThinkPad t43 WiFi Card Replacement: 手順 7、 3の画像 2 IBM ThinkPad t43 WiFi Card Replacement: 手順 7、 3の画像 3
    • Place fingers on the two clips holding the card in place
    • Pull the clips outwards until the the card pops up
    • Pull the card out by pulling out away from your body
    • To replace, follow these steps in reverse order
    • Make sure that the side with the short end is on the left when you put it back in.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
aLiX pIeRRe
メンバー登録日: 03/19/18
855 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018人のメンバー
UMASSD-BERNIER-S18S6G4
4 メンバー
10のガイドは作成済み
2 件のコメント
I need to know what's role of the cables AUX and MAIN because i cut one
M a n i _001 - 返信
AUX and MAIN cables are antenna cables. In this laptop there are two antennas, MAIN and AUX.
If you have a soldering iron, simply solder the two parts of the cable you cut and everything is gonna be fine.
I also recommend using shrink tubing to isolate the soldered part.
Note : laptop can work without this câble, but WiFi speed and stability will suffer.
If you can't solder the câble or can't by a new one, you can try to use only main by pluggin the only remaining antena câble to MAIN and leaving AUX unlpuged.
Brendan -
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 39
過去 30 日: 155
今までの合計 10,502
