メインコンテンツにスキップ
IBM ThinkPad X41 Battery Replacement
  1. IBM ThinkPad X41 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn laptop over, make sure lid side is faced down.
  2. IBM ThinkPad X41 Battery Replacement: 手順 2、 1の画像 1
    • Locate battery release button lock on laptop, and press down.
  3. IBM ThinkPad X41 Battery Replacement: 手順 3、 1の画像 1
    • Hold laptop battery release button and gently pull battery away from laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Magaly Espinoza
メンバー登録日: 09/12/16
183 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016人のメンバー
CSUF-BRUCE-F16S2G4
4 メンバー
8のガイドは作成済み
2 件のコメント
How can you open the battery case and replace the lithium ion cells?
Janie Godfrey - 返信
This could be possible, but it's the hard way.
Open the battery case will be difficult, and you well need to keep the BMS circuit board inside the battery pack then build a battery pack with new cells and reactivate the BMS again as some battery BMS have a security that cut the power output when the BMS has stopped to be powered. So after replacing the cells, the battery might not work as is as the BMS might cut the power output of the battery pack.
I don't know if this battery pack has this kind of security on it's BMS.
Brendan -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 859
