メインコンテンツにスキップ
IBM ThinkPad T42 Wi-Fi Card Replacement
必要な工具と部品
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: 手順 1、 1の画像 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: 手順 2、 1の画像 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - 返信
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - 返信
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: 手順 3、 1の画像 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: 手順 4、 2の画像 1 IBM ThinkPad T42 Wi-Fi Card Replacement: 手順 4、 2の画像 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: 手順 5、 1の画像 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: 手順 6、 1の画像 1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: 手順 7、 1の画像 1
    • Carefully pull it out.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Kevin Rehm
メンバー登録日: 04/19/10
472 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G76
4 メンバー
35のガイドは作成済み
コメント 1 件
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 29
今までの合計 13,752
