はじめに
ThinkPad accepts PPC2700 chips up to 2 GB.
必要な工具と部品
Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
Pry the cover open carefully (flathead screwdriver might help)
To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
Pull the stick out carefully.
In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
7 の人々がこのガイドを完成させました。
