メインコンテンツにスキップ
IBM ThinkPad T42 Modem Daughter Board Replacement
必要な工具と部品
  1. IBM ThinkPad T42 Modem Daughter Board Replacement, Bottom cover: 手順 1、 1の画像 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Modem Daughter Board Replacement, Rear screws: 手順 2、 1の画像 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Modem Daughter Board Replacement, Keyboard and Trackpad: 手順 3、 1の画像 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Modem Daughter Board Replacement: 手順 4、 2の画像 1 IBM ThinkPad T42 Modem Daughter Board Replacement: 手順 4、 2の画像 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Modem Daughter Board Replacement, Plastic Edge Cover: 手順 5、 2の画像 1 IBM ThinkPad T42 Modem Daughter Board Replacement, Plastic Edge Cover: 手順 5、 2の画像 2
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
  6. IBM ThinkPad T42 Modem Daughter Board Replacement, Lower Bracket: 手順 6、 2の画像 1 IBM ThinkPad T42 Modem Daughter Board Replacement, Lower Bracket: 手順 6、 2の画像 2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Modem Daughter Board Replacement, Microphone cover: 手順 7、 1の画像 1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Modem Daughter Board Replacement, Daughterboard Unscrewing: 手順 8、 1の画像 1
    • Next, unscrew the 3 Phillips screws in red.
  9. IBM ThinkPad T42 Modem Daughter Board Replacement, Removing the Daughterboard: 手順 9、 1の画像 1
    • The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
  10. IBM ThinkPad T42 Modem Daughter Board Replacement, Remove Bracket: 手順 10、 1の画像 1
    • Lastly, remove the bracket sitting beneath it.
    • The end!
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Gerald Watanabe
メンバー登録日: 04/14/10
279 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G76
4 メンバー
35のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 4,988
