はじめに
Removal/repair of the display
ツール
パーツ
パーツは指定されていません。
Unscrew the 2 Phillips screws on both sides of the T42's rear.
Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
Unscrew the screws holding down the display.
Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
5 の人々がこのガイドを完成させました。
