メインコンテンツにスキップ
IBM ThinkPad T42 Display Replacement
必要な工具と部品
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: 手順 1、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Display Replacement, Rear screws: 手順 2、 1の画像 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: 手順 3、 1の画像 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement: 手順 4、 2の画像 1 IBM ThinkPad T42 Display Replacement: 手順 4、 2の画像 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: 手順 5、 2の画像 1 IBM ThinkPad T42 Display Replacement, Bezel Removal: 手順 5、 2の画像 2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: 手順 6、 1の画像 1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: 手順 7、 1の画像 1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Austin Kidd
メンバー登録日: 04/21/10
317 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G76
4 メンバー
37のガイドは作成済み
2件のガイドコメント
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - 返信
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 40
今までの合計 13,547
