はじめに
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its fan.
パーツ
パーツは必要ありません。
  1. Close the screen and turn the closed laptop over.
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. Remove the extra RAM cover, by lifting where the screw was and pulling out.
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. Turn the laptop right side up and open the screen.
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. Close the laptop and turn it over.
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. Unscrew the five screws that were hidden by the stickers.
    • Unscrew the five screws that were hidden by the stickers.
  7. Turn the computer right side up and open the screen.
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
    • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
  10. Push apart the retaining clips.
    • Push apart the retaining clips.
    • Note: The card should pop up a little bit.
  11. Pull the wireless network card out.
    • Pull the wireless network card out.
  12. Remove the screw on the left hand side of the case, above the expansion slot.
    • Remove the screw on the left hand side of the case, above the expansion slot.
  13. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  14. Lift the black plastic border by lifting on either side. Once the sides are up, pull the border towards you and away from the screen.
    • Lift the black plastic border by lifting on either side.
    • Once the sides are up, pull the border towards you and away from the screen.
    • When lifting up, there are two pairs of plastic clips hooking into the fan grill. If you pull hard enough the border will come away, but it's better to push the clips with the spudger.
  15. Pull the sheet metal cover away from slot.
    • Pull the sheet metal cover away from slot.
  16. Lift out the expansion slot by starting at the entrance hole and pulling upward.
    • Lift out the expansion slot by starting at the entrance hole and pulling upward.
    • Note: Try wiggling the slot from side to side until it comes out all the way.
  17. Remove the three screws holding down the modem in the upper left corner of the laptop.
    • Remove the three screws holding down the modem in the upper left corner of the laptop.
  18. Lift the modem up, unplugging it from the motherboard as you lift.
    • Lift the modem up, unplugging it from the motherboard as you lift.
  19. Pull out the wire that connects the modem to the screen. Unplug the other cable that attaches the modem to the motherboard
    • Pull out the wire that connects the modem to the screen.
    • Unplug the other cable that attaches the modem to the motherboard
  20. Close the computer screen.
    • Close the computer screen.
    • Remove the four screws on the back of the laptop, near the right and left hinges.
  21. Open the laptop screen.
    • Open the laptop screen.
    • Remove the single screw that secures the left hinge to top of the computer.
  22. Remove a single screw from the metal plate that secures the display cable.
    • Remove a single screw from the metal plate that secures the display cable.
  23. Pull the metal plate away from the display cable.
    • Pull the metal plate away from the display cable.
  24. Disconnect the display cable.
    • Disconnect the display cable.
  25. Carefully pull up the long antenna cables that were attached to the wireless network card.
    • Carefully pull up the long antenna cables that were attached to the wireless network card.
  26. Lift out the screen.
    • Lift out the screen.
  27. Unsnake the black cable from the black plastic frame.
    • Unsnake the black cable from the black plastic frame.
  28. Remove the sheet metal piece, which was underneath the modem.
    • Remove the sheet metal piece, which was underneath the modem.
  29. Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
    • Remove the rubber microphone cover in the upper left hand corner by lifting up the gray metal frame.
  30. Lift away the gray metal frame.
    • Lift away the gray metal frame.
  31. Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
    • Remove three screws near the edge of the computer, holding the optical bay and HDD covers.
    • Remove three other screws on the other side of the covers.
    • You should have six screws in total, three of one size and three of another size.
  32. Lift out the optical bay and HDD covers.
    • Lift out the optical bay and HDD covers.
  33. Lift out the black plastic frame.
    • Lift out the black plastic frame.
  34. Unplug the fan from the motherboard.
    • Unplug the fan from the motherboard.
  35. Remove the three screws on the fan.
    • Remove the three screws on the fan.
  36. Lift the fan out.
    • Lift the fan out.
まとめ
7 の人々がこのガイドを完成させました。
Marissa Blustein
メンバー登録日: 2010年04月16日
453 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G8
4 メンバー
26のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 27,731
