メインコンテンツにスキップ
IBM ThinkPad T30 Wireless Card Replacement
必要な工具と部品
  1. IBM ThinkPad T30 Wireless Card Replacement, Battery: 手順 1、 3の画像 1 IBM ThinkPad T30 Wireless Card Replacement, Battery: 手順 1、 3の画像 2 IBM ThinkPad T30 Wireless Card Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: 手順 2、 3の画像 1 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: 手順 2、 3の画像 2 IBM ThinkPad T30 Wireless Card Replacement, Wireless Card: 手順 2、 3の画像 3
    • Focus on the panel at the center of the Thinkpad.
    • Unscrew the three 4mm Phillips #0 screws that bind the panel cover to the Thinkpad.
    • Lift the panel from the right edge and remove the panel.
  3. IBM ThinkPad T30 Wireless Card Replacement: 手順 3、 3の画像 1 IBM ThinkPad T30 Wireless Card Replacement: 手順 3、 3の画像 2 IBM ThinkPad T30 Wireless Card Replacement: 手順 3、 3の画像 3
    • Before removing the wireless card, identify the three wires that need to be removed.
    • The first two wires that are on the bottom right can be easily unplugged with your fingers by pulling on the white label that comes with the wire.
    • For the last wire on the center right, use a plastic opening tool to pry out the wire.
  4. IBM ThinkPad T30 Wireless Card Replacement: 手順 4、 3の画像 1 IBM ThinkPad T30 Wireless Card Replacement: 手順 4、 3の画像 2 IBM ThinkPad T30 Wireless Card Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tool to pry the hinges on the side of the wireless card. These hinges hold the wireless card in place.
    • The wireless card will pop up at an angle, and can then be easily pulled out.
    • When reinserting a new wireless card, insert the card at the angle that it popped out. Then simply push the card down to lock it back into the hatch.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alex Kost
メンバー登録日: 10/05/12
271 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G20
3 メンバー
16のガイドは作成済み
コメント 1 件
I f i take out this component will the computer act normally The computer has a car diagnostic program installed as an after thought as i wish to be normal computer Do i just remove and ever thing okay thanks Terry
Terry Dollery - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 5,261
