メインコンテンツにスキップ
IBM ThinkPad T30 Hard Drive Replacement
必要な工具と部品
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: 手順 1、 3の画像 1 IBM ThinkPad T30 Hard Drive Replacement, Battery: 手順 1、 3の画像 2 IBM ThinkPad T30 Hard Drive Replacement, Battery: 手順 1、 3の画像 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: 手順 2、 1の画像 1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: 手順 3、 3の画像 1 IBM ThinkPad T30 Hard Drive Replacement: 手順 3、 3の画像 2 IBM ThinkPad T30 Hard Drive Replacement: 手順 3、 3の画像 3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: 手順 4、 2の画像 1 IBM ThinkPad T30 Hard Drive Replacement: 手順 4、 2の画像 2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: 手順 5、 2の画像 1 IBM ThinkPad T30 Hard Drive Replacement: 手順 5、 2の画像 2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
終わりに
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Allie Knauer
メンバー登録日: 10/05/12
90 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G20
3 メンバー
16のガイドは作成済み
コメント 1 件
good description and photos..thanks :]
David - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 60
今までの合計 19,028
