はじめに
This guide will show you every step needed to ensure proper process in replacing a keyboard key for the IBM ThinkPad R40.
必要な工具と部品
Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
Step 6: The key should not be firmly locked into place and functioning normally.
ある他の人がこのガイドを完成しました。
