はじめに
This guide will show you how to replace your display from your laptop. You would need to replace it if you break your display.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Unscrew the coin screw for the hard drive using a coin. Pry off the HDD cover.
Remove the plastic part attached to the bottom of the screen.
Gently pull it from one side and then from another.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
