メインコンテンツにスキップ
はじめに
This guide will demonstrate how to remove and replace the screen on an IBM ThinkPad 560z. A Phillips 00 screwdriver and a push pin are needed for this process.
パーツ
パーツは指定されていません。
  1. Slide the battery release latch to the right.
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Remove the plastic screw covers, then remove the 3 Phillips screws under them. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  3. Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  4. Remove the four Phillips head screws.
    • Remove the four Phillips head screws.
  5. Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  6. Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop. The connector is very fragile, so be careful.
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
終わりに
2 の人々がこのガイドを完成させました。
John Allande
メンバー登録日: 2010年04月15日
64 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 26-27, Regan Spring 2010 Cal Poly, Team 26-27, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S26G27
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 4,698
