この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to properly open up your Hyperkin Retron 3 console in the event you need to make repairs.
必要な工具と部品
In order to get into the system you're going to have to remove the 4 rubber boots on the bottom of the console in order to access 4 hidden screws underneath. The other two screws are already accessible.
You can barely see it but the upper shell is standing upright on the front right corner.
There are 11 screws that need to be removed in order to remove the entire PCB unit.
The AV/Power/NES PCB will be the last to remove during disassembly and first to replace during reassembly.
2 の人々がこのガイドを完成させました。
