メインコンテンツにスキップ
HyperX QuadCast S USB Connector and Auxiliary Port Replacement
必要な工具と部品
  1. HyperX QuadCast S USB Connector and Auxiliary Port Replacement, Gain Control Knob: 手順 1、 3の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement, Gain Control Knob: 手順 1、 3の画像 2 HyperX QuadCast S USB Connector and Auxiliary Port Replacement, Gain Control Knob: 手順 1、 3の画像 3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 2、 3の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 2、 3の画像 2 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 2、 3の画像 3
    • Orientate the microphone with the gain control knob upwards.
    • Pull outwards from the microphone to release the gain control knob.
    • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
  3. HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 3、 3の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 3、 3の画像 2 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 3、 3の画像 3
    • Remove the gain control knob.
    • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
  4. HyperX QuadCast S USB Connector and Auxiliary Port Replacement, I/O Board: 手順 4、 2の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement, I/O Board: 手順 4、 2の画像 2
    • Remove the three 6 mm Phillips #0 screws.
  5. HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 5、 3の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 5、 3の画像 2 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 5、 3の画像 3
    • Begin to pull out the I/O board.
    • Unplug any cables connected to the I/O board.
    • Some of the cables will need to be soldered back to any replacement I/O board to function properly.
  6. HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 6、 2の画像 1 HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 6、 2の画像 2
    • Finish pulling out the I/O board to remove it from the microphone.
  7. HyperX QuadCast S USB Connector and Auxiliary Port Replacement, USB Connector and Auxiliary Port: 手順 7、 1の画像 1
    • Remove the USB-C port.
  8. HyperX QuadCast S USB Connector and Auxiliary Port Replacement: 手順 8、 1の画像 1
    • Remove the auxiliary port.
終わりに
作成者
1人の作成者と共同作成されました。
Nathan Arruda
メンバー登録日: 10/25/22
684 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 UMass Dartmouth, Team 4-1, Sinclaire Fall 2022人のメンバー
UMASSD-SINCLAIRE-F22S4G1
5 メンバー
9のガイドは作成済み
2 件のコメント
do you have a motherboard replace for the original hyperx quadcast? current looking for a replacement right now.
tairkyu - 返信
Unfortunately, HyperX doesn't sell the motherboards separately, making sourcing and replacing the board difficult. With our research, the only difference between the two microphone models is the illumination so the boards and the other features should be the same hardware. We'd recommend trying to source another quad cast for parts if you can find one that doesn't have a damaged board.
Nathan Arruda - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 35
過去 30 日: 193
今までの合計 4,086
