メインコンテンツにスキップ
Husqvarna FE 350 Rear Sprocket Replacement
必要な工具と部品
  1. Husqvarna FE 350 Rear Sprocket Replacement, Rear Sprocket: 手順 1、 1の画像 1
    • Place the motorcycle on a stand so that the rear tire is off the ground.
  2. Husqvarna FE 350 Rear Sprocket Replacement: 手順 2、 2の画像 1 Husqvarna FE 350 Rear Sprocket Replacement: 手順 2、 2の画像 2
    • Use the 27mm wrench to unscrew the nut that holds the axle together. This nut is located on the right side of the motorcycle at the end of the swing-arm.
  3. Husqvarna FE 350 Rear Sprocket Replacement: 手順 3、 3の画像 1 Husqvarna FE 350 Rear Sprocket Replacement: 手順 3、 3の画像 2 Husqvarna FE 350 Rear Sprocket Replacement: 手順 3、 3の画像 3
    • Move to the left side of the motorcycle and remove the axle by pulling it directly out.
    • Move back to the right side and remove the spacer shown in the third picture to ensure that is does not get lost.
  4. Husqvarna FE 350 Rear Sprocket Replacement: 手順 4、 2の画像 1 Husqvarna FE 350 Rear Sprocket Replacement: 手順 4、 2の画像 2
    • Pull up and back on the chain to free the tire.
  5. Husqvarna FE 350 Rear Sprocket Replacement: 手順 5、 1の画像 1
    • Lay the tire on a flat surface with with sprocket facing up.
    • Use the 6mm Torx wrench to unscrew the six bolts holding the sprocket on.
    • Replace the sprocket and screw the bolts back in.
  6. Husqvarna FE 350 Rear Sprocket Replacement: 手順 6、 1の画像 1
    • Be careful that the brake rotor fits in between the brake pads on the caliper.
  7. Husqvarna FE 350 Rear Sprocket Replacement: 手順 7、 1の画像 1
    • Put the chain back on. Start at the bottom and work the chain carefully over the top of the new sprocket.
  8. Husqvarna FE 350 Rear Sprocket Replacement: 手順 8、 3の画像 1 Husqvarna FE 350 Rear Sprocket Replacement: 手順 8、 3の画像 2 Husqvarna FE 350 Rear Sprocket Replacement: 手順 8、 3の画像 3
    • Push the axle back through the swing arm and the wheel.
    • Place the spacer back onto the axle with the square side pointing forward.
    • Thread the 27mm nut back onto the axle.
  9. Husqvarna FE 350 Rear Sprocket Replacement: 手順 9、 1の画像 1
    • Use the 27mm wrench to tighten the nut down.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Bryce Marking
メンバー登録日: 02/02/21
231 ポイント
1ガイドが承認済み
コメント 1 件
C'est bien. je veux apprendre à réparer les motos
Enoch DEMBELE - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 75
今までの合計 1,191
