メインコンテンツにスキップ
Huntington GA41PS-RDS Acoustic Guitar String Replacement
必要な工具と部品
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: 手順 1、 1の画像 1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 2、 3の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 2、 3の画像 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 2、 3の画像 3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 3、 2の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 3、 2の画像 2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 4、 3の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 4、 3の画像 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 4、 3の画像 3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 5、 3の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 5、 3の画像 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 5、 3の画像 3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 6、 3の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 6、 3の画像 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 6、 3の画像 3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 7、 2の画像 1 Huntington GA41PS-RDS Acoustic Guitar String Replacement: 手順 7、 2の画像 2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
終わりに
作成者
1人の作成者と共同作成されました。
Ruhail Khan
メンバー登録日: 01/18/22
145 ポイント
1ガイドが承認済み
チーム
York University, Team R-15, Melo-Thaiss Winter 2022 York University, Team R-15, Melo-Thaiss Winter 2022人のメンバー
YORK-MELO-THAISS-W22SRG15
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 370
