メインコンテンツにスキップ
Huawei u7519 Screen Replacement
必要な工具と部品
  1. Huawei u7519 Screen Replacement, Back Cover: 手順 1、 2の画像 1 Huawei u7519 Screen Replacement, Back Cover: 手順 1、 2の画像 2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Screen Replacement: 手順 2、 2の画像 1 Huawei u7519 Screen Replacement: 手順 2、 2の画像 2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Screen Replacement: 手順 3、 1の画像 1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  4. Huawei u7519 Screen Replacement: 手順 4、 1の画像 1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Screen Replacement: 手順 5、 1の画像 1
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Screen Replacement, Screen: 手順 6、 2の画像 1 Huawei u7519 Screen Replacement, Screen: 手順 6、 2の画像 2
    • To remove front case from the motherboard, first pull back the silver tab.
    • Then remove the orange tab.
  7. Huawei u7519 Screen Replacement: 手順 7、 2の画像 1 Huawei u7519 Screen Replacement: 手順 7、 2の画像 2
    • Once the silver and orange tabs are pulled back, carefully pull the motherboard apart from the front case.
  8. Huawei u7519 Screen Replacement: 手順 8、 1の画像 1
    • Now that the motherboard is separate from the front case, you can discard the original motherboard.
    • The LCD screen can not be removed from the motherboard. Therefore, a new motherboard must be purchased in order to replace this screen.
  9. Huawei u7519 Screen Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • For reassembly:
    • Place the new motherboard on the front case.
    • Snap the tabs back into place.
    • Replace back casing and snap in place.
    • Screw in screws.
    • You can also follow these steps in reverse, which is the same process as outline above.
    • Replacing the power and volume buttons may be tricky. For ease, use tweezers.
    • You have now successfully replaced the screen for the phone.
終わりに
5 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Alicia
メンバー登録日: 02/13/14
34 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014人のメンバー
OSU-MEZA-S14S1G1
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 870
