メインコンテンツにスキップ
Huawei u7519 Camera Replacement
必要な工具と部品
  1. Huawei u7519 Camera Replacement, Back Cover: 手順 1、 2の画像 1 Huawei u7519 Camera Replacement, Back Cover: 手順 1、 2の画像 2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Camera Replacement: 手順 2、 2の画像 1 Huawei u7519 Camera Replacement: 手順 2、 2の画像 2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
    • Save the screws. They will be needed for reassembly.
  3. Huawei u7519 Camera Replacement: 手順 3、 1の画像 1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
    • NOTE: Save the screws. They will be needed for reassembly.
  4. Huawei u7519 Camera Replacement: 手順 4、 1の画像 1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • Note: The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Camera Replacement: 手順 5、 1の画像 1
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Camera Replacement, Camera: 手順 6、 2の画像 1 Huawei u7519 Camera Replacement, Camera: 手順 6、 2の画像 2
    • To remove front encasing from the motherboard, first pull back the orange tabs.
  7. Huawei u7519 Camera Replacement: 手順 7、 2の画像 1 Huawei u7519 Camera Replacement: 手順 7、 2の画像 2
    • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
  8. Huawei u7519 Camera Replacement: 手順 8、 1の画像 1
    • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Marcus Mamarella
メンバー登録日: 02/13/14
36 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014人のメンバー
OSU-MEZA-S14S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 8
今までの合計 517
