メインコンテンツにスキップ
Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
必要な工具と部品
ビデオの概要
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 手順 1、 3の画像 1 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 手順 1、 3の画像 2 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 手順 1、 3の画像 3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 手順 2、 3の画像 1 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 手順 2、 3の画像 2 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 手順 2、 3の画像 3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 手順 3、 3の画像 1 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 手順 3、 3の画像 2 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 手順 3、 3の画像 3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 手順 4、 3の画像 1 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 手順 4、 3の画像 2 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 手順 4、 3の画像 3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 手順 5、 3の画像 1 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 手順 5、 3の画像 2 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 手順 5、 3の画像 3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
終わりに
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
ZFix
メンバー登録日: 12/09/13
191,647 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,501のガイドは作成済み
コメント 1 件
Can i get video guide
filmon - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 90
今までの合計 6,702
