メインコンテンツにスキップ
Huawei Y300 LCD Screen Replacement
必要な工具と部品
  1. Huawei Y300 LCD Screen Replacement, Battery: 手順 1、 2の画像 1 Huawei Y300 LCD Screen Replacement, Battery: 手順 1、 2の画像 2
    • Remove the rear cover at the back by pulling the gap located at the bottom of the phone.
    • Lift up and remove the battery.
  2. Huawei Y300 LCD Screen Replacement: 手順 2、 3の画像 1 Huawei Y300 LCD Screen Replacement: 手順 2、 3の画像 2 Huawei Y300 LCD Screen Replacement: 手順 2、 3の画像 3
    • Leave the phone down on a table.
    • 8 screws are what we need to remove next. There is one hiding below a white sticker.
  3. Huawei Y300 LCD Screen Replacement: 手順 3、 2の画像 1 Huawei Y300 LCD Screen Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Use a screwdriver (T4 if you are using the 54 bit driver kit) to remove the 8 screws along the edges of the phone. There are four in each corner and four in the middle on the sides.
    • Put the screws on the magnetic mat/parts tray or bowl to make sure they are not lost.
  4. Huawei Y300 LCD Screen Replacement: 手順 4、 3の画像 1 Huawei Y300 LCD Screen Replacement: 手順 4、 3の画像 2 Huawei Y300 LCD Screen Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tool by fitting it into the gaps to pull back the frame.
  5. Huawei Y300 LCD Screen Replacement: 手順 5、 3の画像 1 Huawei Y300 LCD Screen Replacement: 手順 5、 3の画像 2 Huawei Y300 LCD Screen Replacement: 手順 5、 3の画像 3
    • On the left of the motherboard there is a ribbon cable that connects the volume rocker to the motherboard, we need to disconnect it.
    • To do this, using either the spudger or tweezers lift up the retention flap holding the cable down.
    • Next using the tweezers carefully pull the ribbon cable away from the socket it was in until it is completely clear of the connector.
  6. Huawei Y300 LCD Screen Replacement: 手順 6、 1の画像 1
    • There are two more ribbon cables at the top that must also be disconnected, to do this simply lift them up from their connecter with the tweezers or with the spudger.
  7. Huawei Y300 LCD Screen Replacement: 手順 7、 2の画像 1 Huawei Y300 LCD Screen Replacement: 手順 7、 2の画像 2
    • Pull back the orange tab. Carefully disconnect this.
  8. Huawei Y300 LCD Screen Replacement: 手順 8、 1の画像 1
    • Once the orange tabs are pulled back, use a plastic wedge to detach the LCD screen.
    • Carefully pull the screen away from the cover and replace the LCD with a new one
終わりに
44 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Shuti Wu
メンバー登録日: 10/20/14
530 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G3
4 メンバー
8のガイドは作成済み
2 件のコメント
good
it a good advise and easy
omeyo innocent - 返信
Its really helpful and so easy ... thanks
Ghulam Qamar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 17,360
