メインコンテンツにスキップ
Huawei Watch Jewel Battery Replacement
必要な工具と部品
  1. Huawei Watch Jewel Battery Replacement, Strap: 手順 1、 2の画像 1 Huawei Watch Jewel Battery Replacement, Strap: 手順 1、 2の画像 2
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Battery Replacement: 手順 2、 2の画像 1 Huawei Watch Jewel Battery Replacement: 手順 2、 2の画像 2
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Battery Replacement: 手順 3、 3の画像 1 Huawei Watch Jewel Battery Replacement: 手順 3、 3の画像 2 Huawei Watch Jewel Battery Replacement: 手順 3、 3の画像 3
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Battery Replacement: 手順 4、 1の画像 1
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Battery Replacement: 手順 5、 2の画像 1 Huawei Watch Jewel Battery Replacement: 手順 5、 2の画像 2
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Battery Replacement, Motherboard: 手順 6、 1の画像 1
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
  7. Huawei Watch Jewel Battery Replacement: 手順 7、 2の画像 1 Huawei Watch Jewel Battery Replacement: 手順 7、 2の画像 2
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Battery Replacement: 手順 8、 1の画像 1
    • Remove the back case.
  9. Huawei Watch Jewel Battery Replacement: 手順 9、 2の画像 1 Huawei Watch Jewel Battery Replacement: 手順 9、 2の画像 2
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Battery Replacement: 手順 10、 1の画像 1
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
  11. Huawei Watch Jewel Battery Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    Spudger
    $2.99
    購入する
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Battery Replacement: 手順 12、 1の画像 1
    • Remove the motherboard.
  13. Huawei Watch Jewel Battery Replacement, Battery: 手順 13、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Picks (Set of 6)
    購入する
    • Use the spudger or opening pick to carefully lift the battery from the watch.
    • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
    • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
終わりに
19 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
ngan tran
メンバー登録日: 02/15/17
498 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 5-3, Passmore Spring 2017 USF Tampa, Team 5-3, Passmore Spring 2017人のメンバー
USFT-PASSMORE-S17S5G3
4 メンバー
3のガイドは作成済み
8 件のコメント
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - 返信
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - 返信
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson -
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - 返信
T2 or T3 Torx ???
Carlos - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 102
今までの合計 22,175
