必要な工具と部品
Open the cover and press the SIM card and Micro SD card in to release them both.
Remove the screw under the hinge cover.
Use a prying tool to loosen the back cover from the display.
There are plastic clips holding the display and back cover together, but they come apart quite easily.
Carefully separate the display unit from the back cover, but not too far.
There is a cable connecting the two together.
Lift the ZIF Connector and remove the Display Cable.
Lay the display to one side.
Flip the ZIF connector to loosen the flex cable for the USB charger port.
It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
Remove the two screws holding the charger port in place.
Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
Insert the display into the back cover.
Replace the screw by the SIM card / Micro SD card slot.
Completed!
2 の人々がこのガイドを完成させました。
3 件のコメント
Is this charger available
Charger port for Huawei s10
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
