はじめに
The microphone is a important part of the phone that allows it to pick up and record audio. This guide will clearly show you how to remove the microphone without damaging other parts of the phone. Before you start please have the correct tools listed underneath as these tools will ensure a successful microphone replacement.
  1. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front. Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
    • Use the opening tool from the iFixit kit to get under the back cover and, gently separate the back from the front.
  2. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver. Remove the 15 screws on the back of the phone  with a Phillips #000 screwdriver.
    • Remove the 15 screws on the back of the phone with a Phillips #000 screwdriver.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard. Disconnect the connectors from the motherboard and gently remove the motherboard.
    • Disconnect the connectors from the motherboard and gently remove the motherboard.
  5. Remove the microphone by lifting it out with the blunt tweezers. Remove the microphone by lifting it out with the blunt tweezers. Remove the microphone by lifting it out with the blunt tweezers.
    • Remove the microphone by lifting it out with the blunt tweezers.
まとめ
Rylan Abraham
メンバー登録日: 2018年09月21日
73 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G7, Riccardelli Fall 2018 University of North Texas, Team S1-G7, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G7
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 42
