メインコンテンツにスキップ
はじめに
The battery is an essential component for the phones ability to function. This guide will clearly show you how to remove the battery without damaging other parts of the phone. Before you start please have the correct tools listed underneath as these tools will ensure a successful battery replacement.
  1. Begin to lever up the back cover of your Huawei Pronto LTE, using an Opening Tool. If you are experiencing difficulties with removing the cover, use the metal spudger. Once all corners of the cover are levered, gently lift the back cover off.
    • Begin to lever up the back cover of your Huawei Pronto LTE, using an Opening Tool.
    • If you are experiencing difficulties with removing the cover, use the metal spudger.
    • Once all corners of the cover are levered, gently lift the back cover off.
  2. Unscrew all 15 screws on the back of the phone using the #000 Phillips head screwdriver, and remove the rear frame. Make sure to hold down the phone. Gently lift the inner cover using the metal spudger.
    • Unscrew all 15 screws on the back of the phone using the #000 Phillips head screwdriver, and remove the rear frame.
    • Make sure to hold down the phone.
    • Gently lift the inner cover using the metal spudger.
  3. Detach the yellow latches along the sides to remove the motherboard. Detach the yellow latches along the sides to remove the motherboard. Detach the yellow latches along the sides to remove the motherboard.
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Make sure all latches are detached and that there are no extra screws, to ensure safe removal of the motherboard. Gently remove the motherboard from the device with the tweezers. Gently remove the motherboard from the device with the tweezers.
    • Make sure all latches are detached and that there are no extra screws, to ensure safe removal of the motherboard.
    • Gently remove the motherboard from the device with the tweezers.
  5. Once the motherboard is removed there should be nothing in the way of the battery. Lift the battery from the top left corner. Lift the battery from the top left corner.
    • Once the motherboard is removed there should be nothing in the way of the battery.
    • Lift the battery from the top left corner.
まとめ
Crystal Edwards
メンバー登録日: 2018年09月21日
255 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G7, Riccardelli Fall 2018 University of North Texas, Team S1-G7, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G7
4 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 157
