メインコンテンツにスキップ
Huawei P9 Lite Motherboard Replacement
必要な工具と部品
  1. Huawei P9 Lite Motherboard Replacement, Back Cover: 手順 1、 2の画像 1 Huawei P9 Lite Motherboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Motherboard Replacement: 手順 2、 1の画像 1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Motherboard Replacement: 手順 3、 1の画像 1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Motherboard Replacement, Motherboard Shield: 手順 4、 1の画像 1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Motherboard Replacement: 手順 5、 2の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 5、 2の画像 2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Huawei P9 Lite Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Remove the SIM card tray.
  7. Huawei P9 Lite Motherboard Replacement: 手順 7、 3の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 7、 3の画像 2 Huawei P9 Lite Motherboard Replacement: 手順 7、 3の画像 3
    • Disconnect the motherboard flex, the battery flex and the antenna cable.
  8. Huawei P9 Lite Motherboard Replacement: 手順 8、 2の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 8、 2の画像 2
    • Disconnect the display flex and the power and volume button cable.
  9. Huawei P9 Lite Motherboard Replacement: 手順 9、 2の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 9、 2の画像 2
    • Unplug the rear camera and the headphone jack.
  10. Huawei P9 Lite Motherboard Replacement: 手順 10、 2の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 10、 2の画像 2
    • Take the camera and the headphone jack out of their recesses.
  11. Huawei P9 Lite Motherboard Replacement: 手順 11、 3の画像 1 Huawei P9 Lite Motherboard Replacement: 手順 11、 3の画像 2 Huawei P9 Lite Motherboard Replacement: 手順 11、 3の画像 3
    • Use a spudger to lift the motherboard carefully.
    • Remove the motherboard assembly.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,226 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,519のガイドは作成済み
コメント 1 件
Aslam-0-alaikum
Sir p9lite ka motherboard mil jya ja to plz bta da kitny ka ha
Rajab Ali - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 38
今までの合計 8,704
