はじめに
Use this guide to replace the back cover of your Huawei P9 Lite.
パーツ
パーツは指定されていません。
  1. Use an opening pick to unclip the rear cover, starting from the bottom corner. Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  4. When the back cover is freed from the adhesive you can pop it off by hand completely.
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
まとめ
12 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 2016年11月23日
33,341 ポイント
170のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
104 メンバー
8,414のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 7
過去 7 日: 71
過去 30 日: 368
今までの合計 16,787
