はじめに
このガイドを参照して、お持ちのHuawei P9 Liteのラウドスピーカーを交換しましょう。
必要な工具と部品
開口ピックを捻って、バックカバーを持ち上げ、接着剤から剥がします。
Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
バックカバーの接着剤が剥がれたら、手で完全に取り外せます。
Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
Polaris -
Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
スマートフォン底部に留められた次のネジを外します:
2.9mm #00プラスネジ 3本
3.8mm #00プラスネジ 4本
これで、ラウドスピーカーユニットを掴んで外せます。
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
12 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
3 件のコメント
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
Same problem here. Any help?
Sir hy how are you. Sir p9lite song speaker not working.
What could you use instead of an opening pick??
Alfredo - 返信
Like, could a guitar pick wor? Or anything else?
Alfredo - 返信
A guitar pick will also do.
Tobias Isakeit -
what can still be used besides guitar pick
Tarshia Thompson - 返信
I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
Andy B - 返信
Heating up aroud the finger sensor to loosen the square adhesive tape ..
Hishamchohan - 返信
If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
gazza667 - 返信
