はじめに
Use this guide to replace the front facing camera in your Huawei P9.
  1. First switch off your phone and remove the SIM card tray. Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port. If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Use an iSclack or a suction handle to separate the display unit from the rear panel. Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Disconnect the finger print sensor using a spudger. Disconnect the finger print sensor using a spudger.
    • Disconnect the finger print sensor using a spudger.
  5. Peel off the conducting fabric. You will have to transfer it to the new camera (careful it's sticky). Unplug the camera connector.
    • Peel off the conducting fabric.
      • You will have to transfer it to the new camera (careful it's sticky).
    • Unplug the camera connector.
    • Now you can remove the front camera.
まとめ
ある他の人がこのガイドを完成しました。
Dominik Schnabelrauch
メンバー登録日: 2016年11月23日
24,860 ポイント
119のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
109 メンバー
7,714のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 32
今までの合計 832
