はじめに
Use this guide to replace the charging board in your Huawei P9 smartphone.
  1. First switch off your phone and remove the SIM card tray. Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port. If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Use an iSclack or a suction handle to separate the display unit from the rear panel. Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Disconnect the finger print sensor using a spudger. Disconnect the finger print sensor using a spudger.
    • Disconnect the finger print sensor using a spudger.
  5. Undo the three Phillips #00 screws. Disconnect the loudspeaker flex connector. Remove the metal bracket (mind the adhesive underneath).
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Remove the metal bracket (mind the adhesive underneath).
  6. Disconnect the motherboard flex cable and the antenna cable. Unplug the headphone jack connector. Unplug the headphone jack connector.
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  7. Now you can easily remove the charging board.
    • Now you can easily remove the charging board.
まとめ
6 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 2016年11月23日
24,860 ポイント
119のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
109 メンバー
7,714のガイドは作成済み
統計データを表示:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 166
今までの合計 3,810
