メインコンテンツにスキップ
Huawei P8 Lite Vibrator Replacement
必要な工具と部品
  1. Huawei P8 Lite Vibrator Replacement, Back Cover: 手順 1、 2の画像 1 Huawei P8 Lite Vibrator Replacement, Back Cover: 手順 1、 2の画像 2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Vibrator Replacement: 手順 2、 3の画像 1 Huawei P8 Lite Vibrator Replacement: 手順 2、 3の画像 2 Huawei P8 Lite Vibrator Replacement: 手順 2、 3の画像 3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Vibrator Replacement, Loudspeaker: 手順 3、 1の画像 1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Vibrator Replacement: 手順 4、 1の画像 1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Vibrator Replacement: 手順 5、 1の画像 1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Vibrator Replacement, Motherboard: 手順 6、 3の画像 1 Huawei P8 Lite Vibrator Replacement, Motherboard: 手順 6、 3の画像 2 Huawei P8 Lite Vibrator Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
  7. Huawei P8 Lite Vibrator Replacement: 手順 7、 1の画像 1
    • Remove the two Torx T5 screws.
    • If there is a tamper evident sticker over your screws remove them to properly seat your driver.
    • Remove the five Phillips #00 screws.
  8. Huawei P8 Lite Vibrator Replacement: 手順 8、 2の画像 1 Huawei P8 Lite Vibrator Replacement: 手順 8、 2の画像 2
    • Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
    • Then remove the top cover.
  9. Huawei P8 Lite Vibrator Replacement: 手順 9、 3の画像 1 Huawei P8 Lite Vibrator Replacement: 手順 9、 3の画像 2 Huawei P8 Lite Vibrator Replacement: 手順 9、 3の画像 3
    • Remove the SIM card and SD card trays.
    • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
  10. Huawei P8 Lite Vibrator Replacement: 手順 10、 3の画像 1 Huawei P8 Lite Vibrator Replacement: 手順 10、 3の画像 2 Huawei P8 Lite Vibrator Replacement: 手順 10、 3の画像 3
    • Remove the volume and power button cable.
    • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If this thermal pad broke or is too dried out you might want to replace it with a new one.
  11. Huawei P8 Lite Vibrator Replacement, Vibrator: 手順 11、 2の画像 1 Huawei P8 Lite Vibrator Replacement, Vibrator: 手順 11、 2の画像 2
    • Pry off the vibrator using a plastic opening tool.
終わりに
ある他の人がこのガイドを完成しました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,296 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,522のガイドは作成済み
コメント 1 件
Doğrusu Güzel Anlatılmış Ve Ben Her Zaman Elektronık Tüm Parçalarda KEndi İşimi Kendım Yaparım Araba Bır Ütü Belkı Bir Mekanık Parça Bu Seferde Titreşim Motorumu Deyiştirmek İstedim Ve Bu Resimler Sayesınde Kötü tornavaıdalarla Bile yarım saatte İşlem Tamam Teşekkur Edıyorum Emegi Geçipte Burada Bunu Paylaşan Herkesten
orcun adana - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,519
