メインコンテンツにスキップ
Huawei P8 Lite Motherboard Replacement
必要な工具と部品
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: 手順 3、 1の画像 1
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: 手順 4、 1の画像 1
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
終わりに
8 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Brayden Mann
メンバー登録日: 02/05/16
639 ポイント
4のガイドは作成済み
チーム
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016人のメンバー
MSU-CARPENTER-S16S1G2
3 メンバー
7のガイドは作成済み
4 件のコメント
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - 返信
mine also need a new mother
anywr l can get it asap
blessed - 返信
Hey
I need p8 lite motherboard
goitsemodimo - 返信
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 8,156
