はじめに
This guide shows you how to replace the motherboard of your Huawei P8 Lite.
パーツ
パーツは指定されていません。
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the three Phillips #00 screws that hold the metal plate in place.
Remove the metal plate with a tweezer.
Unplug the battery flex connector with a spudger.
To reassemble your device, follow these instructions in reverse order and apply adhesive where necessary.
6 の人々がこのガイドを完成させました。
