メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Use this guide to replace the loudspeaker on your Huawei P8 Lite.
  1. Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone. Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool. When all clips are open, remove the back cover from the rest of the phone. If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  5. Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  6. Remove the loudspeaker carefully.
    • Remove the loudspeaker carefully.
終わりに
Dominik Schnabelrauch
メンバー登録日: 2016年11月23日
61,148 ポイント
286のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
116 メンバー
11,200のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 10
過去 7 日: 10
過去 30 日: 38
今までの合計 2,012
