はじめに
This guide will help you replace the battery inside your Huawei P8 Lite phone.
必要な工具と部品
この手順で使用する道具:T5 Torx Screwdriver$9.99
Locate the Loudspeaker at the bottom of the device.
Remove the four black screws using the T5 Torx Screwdriver.
Then use the Phillips #000 Screwdriver to remove the three silver screws.
Locate the adhesive strip underneath the battery. Gently pull on the strip to loosen it enough to remove the battery from the device.
2 の人々がこのガイドを完成させました。
