メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If the camera's glass lens is broken on the back of your Huawei P20 Pro but you can take pictures, then you need to replace that lens. This repair is simple, but requires patience and preciseness. For the repair you will first have to remove the small pieces of shattered glass, then clean the area and glue the new lens with double-sided tape or simply by making 2 points of glue. The goal is to avoid touching the camera itself to avoid scratching it.
  1. Start by placing your phone face down on a clean, well-lit surface.
    • Start by placing your phone face down on a clean, well-lit surface.
    • Wear safety glasses/goggles to prevent your eyes from glass shards. This is very important.
  2. Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal. A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
    • Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal.
    • A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
  3. Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • Else, place double-sided adhesive strips in the gaps between the cameras.
    • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
  4. All done! You can take pictures again like you were able to do before.
    • All done! You can take pictures again like you were able to do before.
終わりに
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
cPix
メンバー登録日: 2016年06月14日
3,128 ポイント
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 19
過去 7 日: 136
過去 30 日: 758
今までの合計 43,545
