はじめに
In any device, the motherboard is the most important component of the system. It is the control center for everything in your tablet. This means that all connections have to go through it. Being the engine of the tablet, the motherboard itself holds everything together. If it is damaged or something spills on it, the tablet would not work. It is the main platform for communication between all other components in the device. The motherboard consists of various components which have their own roles to play in the functioning of the tablet.
必要な工具と部品
Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
Once the battery is removed, the motherboard is ready to be removed.
Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
2 の人々がこのガイドを完成させました。
