メインコンテンツにスキップ
Huawei MediaPad S7-301u Front Camera Replacement
必要な工具と部品
  1. Huawei MediaPad S7-301u Front Camera Replacement, Battery: 手順 1、 3の画像 1 Huawei MediaPad S7-301u Front Camera Replacement, Battery: 手順 1、 3の画像 2 Huawei MediaPad S7-301u Front Camera Replacement, Battery: 手順 1、 3の画像 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Front Camera Replacement: 手順 2、 1の画像 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Front Camera Replacement: 手順 3、 3の画像 1 Huawei MediaPad S7-301u Front Camera Replacement: 手順 3、 3の画像 2 Huawei MediaPad S7-301u Front Camera Replacement: 手順 3、 3の画像 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Front Camera Replacement: 手順 4、 3の画像 1 Huawei MediaPad S7-301u Front Camera Replacement: 手順 4、 3の画像 2 Huawei MediaPad S7-301u Front Camera Replacement: 手順 4、 3の画像 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: 手順 5、 3の画像 1 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: 手順 5、 3の画像 2 Huawei MediaPad S7-301u Front Camera Replacement, Motherboard: 手順 5、 3の画像 3
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Front Camera Replacement: 手順 6、 3の画像 1 Huawei MediaPad S7-301u Front Camera Replacement: 手順 6、 3の画像 2 Huawei MediaPad S7-301u Front Camera Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Front Camera Replacement: 手順 7、 2の画像 1 Huawei MediaPad S7-301u Front Camera Replacement: 手順 7、 2の画像 2
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Front Camera Replacement, Front Camera: 手順 8、 1の画像 1
    • Once the battery is removed, remove the front facing camera from the socket located on the top left of the tablet.
  9. Huawei MediaPad S7-301u Front Camera Replacement: 手順 9、 2の画像 1 Huawei MediaPad S7-301u Front Camera Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • Gently unclip the camera from the motherboard using your fingers or a pair tweezers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Chenet Valmy
メンバー登録日: 09/26/17
213 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S11G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 382
