メインコンテンツにスキップ
Huawei Mate 9 Rear and Front Camera Replacement
必要な工具と部品
  1. Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 手順 1、 3の画像 1 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 手順 1、 3の画像 2 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 手順 1、 3の画像 3
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Rear and Front Camera Replacement: 手順 2、 3の画像 1 Huawei Mate 9 Rear and Front Camera Replacement: 手順 2、 3の画像 2 Huawei Mate 9 Rear and Front Camera Replacement: 手順 2、 3の画像 3
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Rear and Front Camera Replacement: 手順 3、 2の画像 1 Huawei Mate 9 Rear and Front Camera Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Rear and Front Camera Replacement: 手順 4、 2の画像 1 Huawei Mate 9 Rear and Front Camera Replacement: 手順 4、 2の画像 2
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  5. Huawei Mate 9 Rear and Front Camera Replacement: 手順 5、 3の画像 1 Huawei Mate 9 Rear and Front Camera Replacement: 手順 5、 3の画像 2 Huawei Mate 9 Rear and Front Camera Replacement: 手順 5、 3の画像 3
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  6. Huawei Mate 9 Rear and Front Camera Replacement: 手順 6、 2の画像 1 Huawei Mate 9 Rear and Front Camera Replacement: 手順 6、 2の画像 2
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Rogelio Ramirez
メンバー登録日: 06/25/17
524 ポイント
3のガイドは作成済み
チーム
UC Davis, Team S7-G8, Lore Fall 2018 UC Davis, Team S7-G8, Lore Fall 2018人のメンバー
UCD-LORE-F18S7G8
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 2,177
