メインコンテンツにスキップ
Huawei Mate 9 Motherboard Replacement
必要な工具と部品
  1. Huawei Mate 9 Motherboard Replacement, Motherboard: 手順 1、 3の画像 1 Huawei Mate 9 Motherboard Replacement, Motherboard: 手順 1、 3の画像 2 Huawei Mate 9 Motherboard Replacement, Motherboard: 手順 1、 3の画像 3
    • Turn off your Huawei Mate 9 smartphone.
    • Remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Motherboard Replacement: 手順 2、 3の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 2、 3の画像 2 Huawei Mate 9 Motherboard Replacement: 手順 2、 3の画像 3
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Motherboard Replacement: 手順 3、 2の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 3、 2の画像 2
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector.
    • Use a Phillips #000 screwdriver to remove the 1.3 mm screws securing the metal plate.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Motherboard Replacement: 手順 4、 2の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 4、 2の画像 2
    • Using a spudger, disconnect the battery connector.
    • Remove the back cover.
  5. Huawei Mate 9 Motherboard Replacement: 手順 5、 3の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 5、 3の画像 2 Huawei Mate 9 Motherboard Replacement: 手順 5、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the two 1.0 mm screws securing the metal plate.
    • After removing the metal plate, you can now remove the rear camera from its slot.
  6. Huawei Mate 9 Motherboard Replacement: 手順 6、 2の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 6、 2の画像 2
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
  7. Huawei Mate 9 Motherboard Replacement: 手順 7、 3の画像 1 Huawei Mate 9 Motherboard Replacement: 手順 7、 3の画像 2 Huawei Mate 9 Motherboard Replacement: 手順 7、 3の画像 3
    • Use a Phillips #000 to remove the six 1.0 mm screws securing the motherboard.
    • Use a spudger to disconnect the coaxial antenna cables.
    • Disconnect the remaining cables using a spudger.
    • Remove the motherboard completely.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Rogelio Ramirez
メンバー登録日: 06/25/17
524 ポイント
3のガイドは作成済み
チーム
UC Davis, Team S7-G8, Lore Fall 2018 UC Davis, Team S7-G8, Lore Fall 2018人のメンバー
UCD-LORE-F18S7G8
3 メンバー
6のガイドは作成済み
コメント 1 件
Where can I find a replacement motherboard for the Huawei mate 9,eBay doesn't seem to have any.
Mobin Stone Bulaya - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 2,640
