メインコンテンツにスキップ
Huawei Mate 9 Back Cover Replacement
必要な工具と部品
  1. Huawei Mate 9 Back Cover Replacement, Back Cover: 手順 1、 2の画像 1 Huawei Mate 9 Back Cover Replacement, Back Cover: 手順 1、 2の画像 2
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Back Cover Replacement: 手順 2、 2の画像 1 Huawei Mate 9 Back Cover Replacement: 手順 2、 2の画像 2
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Back Cover Replacement: 手順 3、 2の画像 1 Huawei Mate 9 Back Cover Replacement: 手順 3、 2の画像 2
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,598 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,534のガイドは作成済み
コメント 1 件
So apparently they must have welded my phone together with some unknown super exotic alloy from another planet. After spending nearly an hour removing the 2 screws at the bottom of the phone using a borrowed IFIXIT tool kit from a friend I proceeded to destroy a guitar pick, 1 heavy duty guitar pick looking thingy, and 2 separating tools from the kit and all I’ve succeeded in doing so far was breaking the bottom of the back cover of my phone. All I wanted to do was save the 50 bucks the guy quoted me to fix the charging port but now I’m thinking that’s a pretty good deal after you add up the cost of repair parts for demolishing my phone. $28.00 for a new back cover that will take 6 weeks to get , a new digitizer has to be over a hundred bucks, and how do you put a price on the frustration this is going to be if I keep going? Do yourself a favor and have someone else work on your device while it can still be saved. These 2 suction cups seem to be stronger than me and I’m jacked!!!
Randy Simpson - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 29
今までの合計 5,074
