はじめに
This guide will show you how to replace the buttons on a Huawei M750 smartphone.
必要な工具と部品
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Use a pair of tweezers to grab hold of each button on an edge from inside of the casing and pull out to remove.
If the buttons aren't broken and the phone just isn't getting the signal when the button is depressed, try replacing the actual electronic board under the buttons replaced in the last step.
Using the plastic opening tool, insert just under the electronic board and apply slight pressure upward.
