メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide show the process of back panel replacement on the Huawei M750.
パーツ
パーツは指定されていません。
  1. Depress the top of the battery cover, and pull downwards towards the base of the phone.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Remove the battery by levering the battery out, using the cut just below the camera.
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Using the T5 Torx screwdriver, remove the six 6mm screws. Using the T5 Torx screwdriver, remove the six 6mm screws.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Using the opening tool, pry the back panel from the front panel. Work your way around the phone until the panels separate evenly.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
終わりに
ある他の人がこのガイドを完成しました。
Kshitiz Thapa
メンバー登録日: 2018年02月11日
389 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S1-G6, Thompson Spring 2018 University of North Texas, Team S1-G6, Thompson Spring 2018人のメンバー
UNT-THOMPSON-S18S1G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 143
