はじめに
The logic board is the main circuit board that drives all the information to the various parts on the tablet. If the tablet stops working and it is not the battery being faulty, then the logic board is the next part that needs to be checked. Use this guide to replace the logic board within a few steps.
必要な工具と部品
Place the tablet on a flat clear surface to keep the screen safe.
Slide the larger portion of the back cover off the tablet.
This will reveal the battery.
Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
ある他の人がこのガイドを完成しました。
