はじめに
This guide details how to remove the motherboard from the frame.
必要な工具と部品
Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
Gently pull out the Sim Card tray and set it aside.
8 の人々がこのガイドを完成させました。
