メインコンテンツにスキップ
Huawei Honor 6x Fingerprint Scanner Replacement
必要な工具と部品
  1. Huawei Honor 6x Fingerprint Scanner Replacement, SIM Card: 手順 1、 1の画像 1
    • Turn off the device.
  2. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 2、 2の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 2、 2の画像 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 3、 1の画像 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 4、 1の画像 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: 手順 5、 2の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: 手順 5、 2の画像 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 6、 3の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 6、 3の画像 2 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 6、 3の画像 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 7、 2の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 7、 2の画像 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 8、 3の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 8、 3の画像 2 Huawei Honor 6x Fingerprint Scanner Replacement: 手順 8、 3の画像 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 9、 1の画像 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 10、 2の画像 1 Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: 手順 10、 2の画像 2
    • Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
  11. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 11、 1の画像 1
    • Apply heat around the finger print scanner assembly using a heat gun or hair dryer.
  12. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 12、 1の画像 1
    • Separate the fingerprint scanner assembly from the back panel using a spudger.
    • This step can be difficult. You may consider using a metal spudger.
    • Be careful not to damage the black rubber adhesive around the fingerprint scanner. It is needed for water and dust resistance.
  13. Huawei Honor 6x Fingerprint Scanner Replacement: 手順 13、 1の画像 1
    • Remove the finger print scanner from the device by lifting it with two fingers.
    • When reattaching the fingerprint scanner assembly, additional adhesive may be required.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tessa Kemper
メンバー登録日: 10/08/18
591 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G5
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 32
今までの合計 1,393
