メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
In this guide, we're going to show you how to replace the broken screen/digitizer on your Huawei H881C
  1. This is where we begin! At the bottom of the phone, pull the plastic back cover off. Ahh, the battery. Simply pull the battery up and out of the housing.
    • This is where we begin! At the bottom of the phone, pull the plastic back cover off.
    • Ahh, the battery. Simply pull the battery up and out of the housing.
  2. 8x T5 torx screws are what we need to remove next. There is one hiding below a black sticker. WARNING: This will void your warranty!
    • 8x T5 torx screws are what we need to remove next. There is one hiding below a black sticker. WARNING: This will void your warranty!
  3. Now that the screws are removed, grab a spudger tool or a thick guitar pick. Start at the volume rocker and work your way around the phone by carefully pulling back the frame. Now that the screws are removed, grab a spudger tool or a thick guitar pick. Start at the volume rocker and work your way around the phone by carefully pulling back the frame. Now that the screws are removed, grab a spudger tool or a thick guitar pick. Start at the volume rocker and work your way around the phone by carefully pulling back the frame.
    • Now that the screws are removed, grab a spudger tool or a thick guitar pick. Start at the volume rocker and work your way around the phone by carefully pulling back the frame.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. We're inside! At this step, there are 3 ribbon cables we need to disconnect to continue. Carefully pull these ribbon connections up. We're inside! At this step, there are 3 ribbon cables we need to disconnect to continue. Carefully pull these ribbon connections up. We're inside! At this step, there are 3 ribbon cables we need to disconnect to continue. Carefully pull these ribbon connections up.
    • We're inside! At this step, there are 3 ribbon cables we need to disconnect to continue. Carefully pull these ribbon connections up.
  6. Under the screen/digitizer connection, there is one more cable. Carefully disconnect this one was well. Remove the camera by pulling straight up.
    • Under the screen/digitizer connection, there is one more cable. Carefully disconnect this one was well.
    • Remove the camera by pulling straight up.
  7. Don't mind the ugly "circles". What is circled is the clips you need to pull back to remove the motherboard from the frame. Your fingernail will work perfect for this. Let's remove the motherboard. With your right hand, slowly pull back the motherboard. With you left hand, guide the ribbon cable through the hole to avoid damaging it.
    • Don't mind the ugly "circles". What is circled is the clips you need to pull back to remove the motherboard from the frame.
    • Your fingernail will work perfect for this.
    • Let's remove the motherboard. With your right hand, slowly pull back the motherboard. With you left hand, guide the ribbon cable through the hole to avoid damaging it.
  8. Now that the motherboard is out, this is the screen/digitizer/LCD assembly. From here, we need to only remove the digitizer. We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer! We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer!
    • Now that the motherboard is out, this is the screen/digitizer/LCD assembly. From here, we need to only remove the digitizer.
    • We recommend using a heat gun or a hot plate if you have one. If you don't have either, use a blow dryer!
    I bought a kit from ebay, and it came with a sticker type paper which im guessing is this adheasive but how do i put it on the frame?
    Sam - 返信
  9. After its hot enough, use a thick guitar pick to peel back the broken screen from the frame. Be careful, it may be hot and glass could get everywhere. Once you've removed the old screen/digitizer, apply new adhesive on the frame and put the new part on. Make sure that you get the old adhesive peeled off. We recommend heating the adhesive before applying the new screen for better bonding. That's it! Now, follow the steps backwards to reassemble your device. Congrats! You've replaced the screen!
    • After its hot enough, use a thick guitar pick to peel back the broken screen from the frame. Be careful, it may be hot and glass could get everywhere.
    • Once you've removed the old screen/digitizer, apply new adhesive on the frame and put the new part on. Make sure that you get the old adhesive peeled off. We recommend heating the adhesive before applying the new screen for better bonding.
    • That's it! Now, follow the steps backwards to reassemble your device. Congrats! You've replaced the screen!
終わりに
10 の人々がこのガイドを完成させました。
GadgetERService
メンバー登録日: 2013年11月22日
1,604 ポイント
2のガイドは作成済み
チーム
Minnesota Repair Techs Minnesota Repair Techs人のメンバー
Community
3 メンバー
2のガイドは作成済み
2 件のコメント
what do you use as an adheasive?
Randy Edwards - 返信
Randy, I'm extremely late responding to your post. I use what the industry calls, "red tape". This stuff is perfect for pretty much any electronic repair, especially iPads.
GadgetERService -
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 19,198
