はじめに
In this guide, we're going to show you how to replace the broken screen/digitizer on your Huawei H881C
This is where we begin! At the bottom of the phone, pull the plastic back cover off.
Ahh, the battery. Simply pull the battery up and out of the housing.
Don't mind the ugly "circles". What is circled is the clips you need to pull back to remove the motherboard from the frame.
Your fingernail will work perfect for this.
Let's remove the motherboard. With your right hand, slowly pull back the motherboard. With you left hand, guide the ribbon cable through the hole to avoid damaging it.
After its hot enough, use a thick guitar pick to peel back the broken screen from the frame. Be careful, it may be hot and glass could get everywhere.
Once you've removed the old screen/digitizer, apply new adhesive on the frame and put the new part on. Make sure that you get the old adhesive peeled off. We recommend heating the adhesive before applying the new screen for better bonding.
That's it! Now, follow the steps backwards to reassemble your device. Congrats! You've replaced the screen!
10 の人々がこのガイドを完成させました。
2 件のコメント
what do you use as an adheasive?
Randy, I'm extremely late responding to your post. I use what the industry calls, "red tape". This stuff is perfect for pretty much any electronic repair, especially iPads.
