メインコンテンツにスキップ
Huawei Ascend Y300 Rear Facing Camera Replacement
必要な工具と部品
  1. Huawei Ascend Y300 Rear Facing Camera Replacement, Rear Facing Camera: 手順 1、 1の画像 1
    • Place the phone screen down on a flat surface. Underneath the camera there will be a indentation, place your thumb or pointer finger on the indentation and pull gently up towards you. The back of the phone should pop off easily.
  2. Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 2、 2の画像 1 Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing. By the battery you will find a similar indentation; place your thumb in the indentation and lift the battery towards you. The battery will come right out.
  3. Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 3、 3の画像 1 Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 3、 3の画像 2 Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 3、 3の画像 3
    • Along the edges of the phone you will find 8 screws, to remove these screws use a screwdriver( T5 if you are using the screwdriver found in the ifixit 54 bit driver kit)
    • Take the screws out by twisting left and set them in a spot where you will not lose them.
  4. Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 4、 2の画像 1 Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame.
  5. Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 5、 2の画像 1 Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 5、 2の画像 2
    • After removing the phone's frame, you will see the camera placed in a metallic cube, to remove the cube lift the edge gently and pull to the left.
    • You will notice the cube is attached to a copper ribbon, do not separate the cube from the ribbon!! it is attached.
  6. Huawei Ascend Y300 Rear Facing Camera Replacement: 手順 6、 1の画像 1
    • CONGRATULATIONS!!! you have successfully completed this guide, please share this guide with your friends
    • Yay! Party time don't forget the bean dip
終わりに
作成者
2人の作成者と共同で作成されました。
Julie Vasquez
メンバー登録日: 11/30/17
133 ポイント
1ガイドが承認済み
チーム
Coast Union High School, Team S1-G4, Hartzell Fall 2017 Coast Union High School, Team S1-G4, Hartzell Fall 2017人のメンバー
CUHS-HARTZELL-F17S1G4
2 メンバー
2のガイドは作成済み
コメント 1 件
Very specific and thorough. Wonderful job ladies!
Dan Hartzell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 459
